2G Coil pack help!
SEVEN2NiNE
Jan 26, 2013
Coatesville, Pennsylvania
So as all of you know it's stuffed under the intake (very stupid place imo) What do I remove to get it out as easily as possible? The fuel rail? I am fixing it on my lunch break so the fastest way would be best option. The Haynes manual doesn't really tell you.
If memory serves me, you only need to unbolt (2 bolts?) the bracket your packs are mounted to from your intake manifold. You'll probably need to unplug a few things, but you should be able to take it out without taking your fuel rail off. Its a tight squeeze, but you should be fine.
You sir are right, it was very easy. Thanks dude!
