2g re-wired coil pack
hionboost
Jul 25, 2013
Elyria, Ohio
I re-wired this coil pack due to the fact that my connector ohm readings were too high and was having a weak spark! Max range on the primary (harness from coil pack) is .86 ohm my readings were 1.4 @ the harness. Coil pack ohm readings on the secondary (coil pack) were fine. My wires were also frayed from rubbing on the intake manifold. I got the same out of spec readings with my ohm meter after wire repair! So I decided to re-wire with some 10ga wire instead of the puny 14 ga. This re-wire brought my ohm reading down to .86 where it should be at. Should also provide a stronger spark hopefully. Yet to test out as I been working a lot lately... I put this here in case it can help anybody in any way. Tell me what y'all think?
Thanks! No, I haven't used it yet as my fuel injectors are out getting serviced the y were clogged up with old gas... I kinda can't wait to try the coil pack out actually! Maybe be better then a COP setup with some good plug wires. Idk... I will post rest results when my injectors are done. But all the ohm readings at the harness and coil pack are within spec, just waiting to try.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
