Greddy EGT Wiring question
DanThMan1983
245
Dec 24, 2005
Omaha, Nebraska
Ok so I am hooking up two gauges. The AEM wideband gauge was simple, used power from the cig lighter and ground and that was done. I am having trouble with the greddy egt gauge. RED> 12v power source(gonna use cig lighter), ORANGE> Ignition Line(where do I run this to?) , WHITE> Parking light source(If I use the parking light wire from the fuse panel its gonna get power any time the key is on because its ground side switched, you guys are not running this wire to the engine bay to the fog lamp relay are you?), BLACK>Ground wire(Got this one taken care of)
Just cant figure out the Orange ignition wire and the White parking light source.
Oh and its on a 92 GSX.
Thanks if you can help guys.
I have all three in the same place because I am lazy. The light switch relay should be in the fuse panel by your left foot. It could be tied in there but I did not do it that way. Sorry that I could not be more help.
Well the fog/parking lamp relay is in the engine bay so that doesnt help. I currently have all three powers on the cig lighter so it gets power when the key is on. Really wish I knew an easier way to get parking lamp switched power to the gauge.
