Gready knock-off BOV
preludeachris
295
3
Sep 29, 2011
Lincoln, Nebraska
Hey guys, has anyone ever had problems with the Gready knock off BOV? I have mine on from the FMIC kit from PR and Im pretty sure its boost leaking and making ALOT of noise...just get a something else? Also I have A BLITZ BOV but its not set up for the hard pipe. Suggestions?
I have both springs in mine, and both vacuum ports connected. I did the single spring mod for a while but found out it starts leaking at like 5psi with only 1 spring. Put both springs back in and it holds 25+ psi.
With both vaccum ports connected I get zero flutter. Heres a quick video just cruising. Yes its recirculated
[ame]http://www.youtube.com/watch?v=_8icjdsOZJ0[/ame]
Top nipple goes to a vacuum source on the intake manifold.
Bottom nipple goes to a boost source.
Dang, I am really glad you posted this Kyle. I've been having an issue with mine getting it to hold with the 1 spring, but flutter with the second. I'll have to put the other spring back in and hook up a boost source. That sounds great!
No problem, I also have the adjustment screw very loose. But hooking up the lower nipple made it sound and function alot better.
  • Wanted 6 bolt NT water pipe
    • chrisman287
