MyBeatGSX
- 1,333
- 29
- Jul 17, 2005
Southington,
Connecticut
First off, I'm very mad at Dejon Tool. The LIC piping on this kit doesn't even come remotely close to fitting. Even after going out and buying $30 worth of longer couplers the fitment is still horrible and I'm having a hard time keeping the couplers connected for any length of time. I took me longer to connect the J-pipe to the LIC pipe than the entire FMIC install did.
Now aside from that. How should the car feel? I've been afraid to make a 1st-3rd gear pull because I'm unsure of the car's state of tune now. I was expecting it to be noticably faster, at least as much of a difference as putting on an exhaust. All I know is that 1st gear is very soft and feels slower than 2nd gear did before. Is this just lag because of the larger air volume? The car just feels all around slow, runs bad, there's hits of misfires at WOT, its just all around crap. The only explaination I could see is a boost leak. However I did SEVEN (7), repeat SEVEN boost leak tests. Someback to back, some at different times, before driving and after driving etc. All of them where nearly perfect. This morning with a stone cold motor I pressurized to 20psi, there was a small leak at the AFPR (common with the aeromotives anyway), so I fixed that with some thread sealant. I retested after a few minutes. At 20psi WITH the MBC hooked up (and just my finger sort of blocking the bleed hole), it dropped 1psi every FIVE (5) seconds. I think that's good for a cold motor don't you?
Do I have a fuel problem? I don't see how just putting on a FMIC could make it run that much leaner. I also added 5% (and now 7% today) across the board on the SAFC, just to be safe. I doubt its tune related though, it runs like garbage at part throttle too.
I have no idea what to think, a boost leak would seem like the obvious answer but the car couldn't be any more leak free.
I don't have a wideband or even an EGT. As I said in the original post I put the AFC 7% richer across the board. Does that sound like enough? Should I go 10-15% just to be safe? I'd rather smoke black than blow something up while I wait a WEEK before I can get to the dyno. If it makes a difference to anyone, my old tune was done on stock fuel pump wiring (running around 11.3). My idle fuel pressure is up 5psi now, so I'm sure its running rich at all points from that as well. And before someone makes a wiseass remark, I didn't want to turn the fuel pressure back down without a wideband to see how it effected things. Not to mention I can't get the pressure any lower, but that's a different post.
) guy with like the Country's fastest N/T or something like that right? I've seen you up there a few times. At least I know what you say is reliable.
And I know I have plenty of fuel, and that I'm not knocking. So whats the reason for my power droping off above 5500rpm. Or is it the exaust not being able to flow?
I'm going to see if VR will make me a side exit that can just go on a diagonal (sp?) from the DP to the rear of the passenger door, no muffler, nothing special. Just something so it isn't dumping under my seat where I have to smell it in the winter.
