nightspeed87
- 1,761
- 12
- May 2, 2006
Tampa,
Florida
once i get my new engine in im only going to have open 3in dp for a good minute, ( hope short shifting throughout city driving helps to keep noise down, i dont know how loud my set up is going to be ) And i like your cutting the front bumper idea, i think it would even benefit more on a 1g because the bumpers air dam seem even more smaller and restrictive on the 1g cars.... I dont want a huge front mount core on my car, i think those would work better for cars with huge turbos pushing 25lbs of boost and up... I just want a smaller fmic on mines... Before you put your fmic did you have stock lower and upper icps? If so that would explain your drastic change in a/f values and flow, because the front mounts hard pipeing is flowing a lot more cfm than the crappy small flexible hoses that come on the car stock... Allowing the turbo to push more air even at the same boost level I imagen ( similar to a bigger turbo pushing more cfm at the same boost as a smaller turbo) So you opened up the intake tract a lot, and your brushing off more heat, and maybe at higher rpm the intercooler is heat soaking a little ( might be maxing your turbos efficiency point maybe?? )... Well at least thats my guess, ( so no need to correct me if im wrong just a thought ) but good luck with your set up.
