got new plugs today, need help!
Like no skillz said, they are the correct plugs recommended by the factory and should be good up until you start making higher than 17+ psi.
The temperature rating on the spark plug doesn't have much to do on the external environmental temperature. It refers to the stability and combustability of the interior environment of the cylinder.
At normal operating conditions at approx less than 20PSI, 6s will perform better than 7s.
To each his own, but IMO I like the 7's much better. And it's true...plugs work with the heat in the cylinder itself...but you've never seen what 100 degree plus outdoor temps can do to your little 4 banger either now have you Mr. Jersey ;)
OK so i should be good when i set my car to 15psi? whats funny is, i had the 8's in here before the 6's i just put in. it ran fine... now, i have my 6's gapped to .028". is that OK?
That is the proper gap. I wrote a FAQ on this topic. It's somewhere on here. I'll have to SEARCH for it. ;)
[Oh, why should you be different?]
