crimsondragon
- 4,300
- 51
- Dec 17, 2006
East Brunswick,
New Jersey
On my quest to eliminate wheel hop and have stiffer motor mounts, I have been trying to finish my install of Prothanes. I did the driver side and front about a year ago. Those went in and out quickly. I started up again recently and did my rear mount last weekend. It was a pain considering the inserts totally did not fit and I had to burn the rubber out and fill it with construction grade polyurethane. Very stiff though. The tranny mount has given me the most trouble so far. I am not able to clear those god damn studs at all. My engine has bottomed out to the cross member so no way the tranny can move down further. So I decided the only thing left to do is cut the damn studs.
The farthest one in the back worked great. It clears the stud and there's plenty of thread left. This is most likely due to the room from removing the battery. However, the two inner ones are blocked by the fuse box and the harness. I had to squeeze my dremel in between to get it. And even then I only cut it halfway before my cutting wheel snapped off. Put on another one and that snapped off too.
So now here I sit thinking how to do this. It's pissing me off slowly. I need to make a trip to the hardware store.
