nice97civic
- 442
- 51
- Jan 29, 2004
lancaster,
Pennsylvania
I know this is the tuning section and the sensor is tuning related but the question is around where you all are mounting your sensors? I have a mostly stock 2g engine bay and so space is pretty limited. The fuel return setup is stock and the fuel return line itself is pretty short. Are you setting the sensor up in-line with the return after the afpr and then mounting to the firewall where some of those stock mounting locations are? I'm using the sensor below with the extremepsi mounting block. Any suggestions would be great, thanks.
