Global and deadtimes FIC 1050's
Firegst
94
Aug 29, 2012
Queen Creek, Arizona
Was wondering if anyone knew the global and deadtimes for the FiC injectors specifically the 1050's. I searched and found the global and times for the 1000's but not the 1050's
1000's were -55 and 330
Should I just use like -56 or -57 and 330?
If anyone has used these before or had anyluck with a specific global and deadtime please share!
Yeah I have them. However every car is different. For pump gas at 42ish fuel pressure I would run -57. Dead time will start at 330. I think mine ended up being lower then that. Around 2XX something. Best way to do it is set the global. Then look at your airflowperrev along with what hz your at and move that slider in maf comp up or down depending on where the airflowperrev is at. You want to get .25
That will get your combined fuel trim within spec too. Easiest way I found.
Make sense?
Thanks for the global I will def use 57 57.1 as far has deadtimes I haven't used link once yet, I order a cable so that i could it should be here tommorow. Gofer tuned the car so I might just put the global and times in an let him or some else tweak it and send it back to me.
Thanks for the super fast response's!
