5150DSM
Supporting VIP
- 856
- 4
- Jan 5, 2004
Sacramento,
California
Well, after 3 years I finally get to build my beast.
The stocker has 115,00k on it and has been abused with just about every bolt-on I could aquire. I ran a best of 12.4 @ 108 on the 14B still on the car and I still DD my car and occasionly deliver pizza as well. However, my last compression check showed 100psi in a couple of cylinders and I burn, leak and blow oil like nobody's business. My gas milage sucks and things are just plain falling apart. So...
I picked up another 6 bolt block and sent it of for some machine shop love. Hot-tanked, magnafluxed and thermal cleaned, bored 0.020" over and decked to a mirror finish. Also had some ARP's installed for insurance.
I then purchased my bottom end from Slowboy.(Thanks Mike and Candy) Wiseco's @ 9.0:1on Scat rods w/ARP 2000's. ACL main and rod bearings, Mitsu MLS head gasket, BSEK and of course a full gasket set, including timing belt and tensioner(s). I already have a "stage II" head and a Shep prepped tranny to mate everything up; footwork and tuning are done as per my profile, so now I just need a turbo.
I'm looking to get around 550-600 from the turbo and I will probably spray another 100 on the track. Right now I'm looking at the SCM5252E or the SCM6152E or maybe the SCM6031E. They are all in the same price range and all will get me where I want to be but my question is, which will do it most efficiently? None are BB and I understand they will be somewhat laggy, but how laggy and is the difference in spool times vastly different between the turbo's?
Thanks for any input you guys can offer. I'm going big but I want to make the right moves the 1st time around.
Aloha
Aloha
. Considering wanting a mitsu housing, research on the seldom discussed 25G. Talk to FP. They'll probably steer you away from it. But I've heard they seam to function OK internally gated. You will have lag But probably be under 5K. Still, does anyone run a 600whp internally gated 2.0?
