Getting ready to build my gsx please look over my parts list
1997_GSX
714
6
Jul 29, 2008
Keyser, West Virginia
ARP Headstuds + Cometic Headgasket: 90-99 Mitsubishi Eclipse ARP Headstuds + Cometic Headgasket: 90-99 Mitsubishi Eclipse
It is always a good idea to replace both the head gasket and head studs at the same time. With that in mind, we've decided to offer a package ...
Selected options:
Model: 7-Bolt
Bore Size: 85.5mm
$ 168.99 x = $ 168.99
Ships in 24 hours
Eagle Rods + Wiseco Piston Combo: Mitsubishi Eclipse Eagle Rods + Wiseco Piston Combo: Mitsubishi Eclipse
The basic building blocks for those seeking 600+ Horsepower. Get it together and save on already great prices!
Selected options:
Model: 7-Bolt
Bore Size: .020 over
Compression: 8.3:1
$ 727.95 x = $ 727.95
Ships in 24 hours
Brian Crower Camshafts & Valve Springs/Retainers Combo: Mitsubishi Eclipse 90-99 Brian Crower Camshafts & Valve Springs/Retainers Combo: Mitsubishi Eclipse 90-99
Here is the ultimate package deal to save now! Included in this kit are a pair of Brian Crower intake and exhaust camshafts and a set of Valve Spri...
Selected options:
Camshaft Profile: 272/272 Degrees
$ 549.00 x = $ 549.00
Ships in 24 hours
ACL Race "Tri-Metal" Rod Bearing Set: Mitsubishi Eclipse 7-Bolt ACL Race "Tri-Metal" Rod Bearing Set: Mitsubishi Eclipse 7-Bolt
Part number: 4B1185H
Selected options:
$ 33.09 x = $ 33.09
Ships in 24 hours
OEM Oil Pump Front Case : Mitsubishi Eclipse 7 Bolt OEM Oil Pump Front Case : Mitsubishi Eclipse 7 Bolt
Brand New Mitsubishi OEM replacement oil pump front case.
Gaskets sold seperately. Please select options below
Part Number: ...
$ 219.00 x = $ 219.00
Ships in 24 hours
OEM Engine Overhaul Complete Block/Head Gasket Set : Mitsubishi Eclipse 2G 7 Bolt OEM Engine Overhaul Complete Block/Head Gasket Set : Mitsubishi Eclipse 2G 7 Bolt
Brand new OEM complete engine gasket set. Includes all gaskets needed for a complete engine overhaul (block and head). Also includes all necessary ...
$ 247.00 x = $ 247.00
Ships in 24 hours
Extreme PSI Timing Belt Kit: Mitsubishi Eclipse 90-99 Extreme PSI Timing Belt Kit: Mitsubishi Eclipse 90-99
Selected options:
Timing Belt: OEM MD326059
Tensioner: 95-99 MD308086
Tensioner Pulley: 95-99 MD182537
Idler Pulley: 90-99 MD156604
Balancer Pulley: Not Selected
Balance Shaft Belt: Not Selected
Balance Shaft Eliminator Kit: Selected
$ 253.25 x = $ 253.25
Ships in 24 hours
Brian Crower Stainless Steel Exhaust Valves : Mitsubishi Eclipse 90-99 Brian Crower Stainless Steel Exhaust Valves : Mitsubishi Eclipse 90-99
STAINLESS STEEL VALVES
BC valves are made from premium stainless steel, fully machined and swirl polished for ultimate air flow. Dished head f...
$ 129.50 x = $ 129.50
Ships in 24 hours
Brian Crower Stainless Steel Intake Valves : Mitsubishi Eclipse 90-99 Brian Crower Stainless Steel Intake Valves : Mitsubishi Eclipse 90-99
Ships in 24 hours
Supertech Intake Valve Stem Seals: Mitsubishi Eclipse 90-99 Supertech Intake Valve Stem Seals: Mitsubishi Eclipse 90-99
Supertech 6.6mm Intake Valve Stem Seals (Polyacrylic Material)
Selected options:
Size: VS-M6.6I - Standard
$ 9.99 x = $ 9.99
Ships in 24 hours
Supertech Exhaust Valve Stem Seals: Mitsubishi Eclipse 90-99 Supertech Exhaust Valve Stem Seals: Mitsubishi Eclipse 90-99
Supertech 6.6mm Exhaust Valve Stem Seals (Viton Material)
Selected options:
Size: VS-M6.6E - Standard
$ 14.99 x = $ 14.99
Ships in 24 hours
Supertech Exhaust Valve Guides: Mitsubishi Eclipse 90-99 Supertech Exhaust Valve Guides: Mitsubishi Eclipse 90-99
Selected options:
$ 39.99 x = $ 39.99
Ships in 24 hours
Supertech Intake Valve Guides: Mitsubishi Eclipse 90-99 Supertech Intake Valve Guides: Mitsubishi Eclipse 90-99
Selected options:
$ 39.99 x = $ 39.99
Ships in 24 hours
ACL Aluglide Thrust Washer Set: Mitsubishi Eclipse 1997-1999 7-Bolt ACL Aluglide Thrust Washer Set: Mitsubishi Eclipse 1997-1999 7-Bolt
Part number: 1T1219
$ 11.50 x = $ 11.50
Ships in 24 hours
ACL Race "Tri-Metal" Main Bearing Set: Mitsubishi Eclipse 1997-1999 7-Bolt ACL Race "Tri-Metal" Main Bearing Set: Mitsubishi Eclipse 1997-1999 7-Bolt
Part number: 5M1219H
Selected options:
$ 55.50 x = $ 55.50
Ships in 24 hours
Oil Filler Cap : Mitsubishi Lancer EVO VIII & IX Oil Filler Cap : Mitsubishi Lancer EVO VIII & IX
Brand new OEM oil filler cap. Rubber seal are included.
Part number: MN163112
Fits: Mitsubishi Lancer Evolution VIII 03-05 GS...
$ 14.83 x = $ 14.83
Ships in 24 hours
OEM Oil Filter : Mitsubishi Eclipse 95-99 OEM Oil Filter : Mitsubishi Eclipse 95-99
Brand New Genuine Mitsubishi Oil Filter
$ 6.50 x = $ 19.50
Ships in 24 hours
ARP Main Studs: Mitsubishi Eclipse 90-99 ARP Main Studs: Mitsubishi Eclipse 90-99
Part Number: 207-5401
Model: Mitsubishi Eclipse 1990 - 1999
Note : For 4G63
$ 59.95 x = $ 59.95
Ships in 24 hours
Garrett GT Dual Ball Bearing Oil Drain Gasket Garrett GT Dual Ball Bearing Oil Drain Gasket
$ 3.00 x = $ 3.00
Ships in 24 hours
Garrett/BEP/Turbonetics T3/T4 Turbo Oil Drain Gasket Garrett/BEP/Turbonetics T3/T4 Turbo Oil Drain Gasket
$ 3.00 x = $ 3.00
Ships in 24 hours
Prothane Motor Mount Inserts: Mitsubishi Eclipse 95-99 M/T Only Prothane Motor Mount Inserts: Mitsubishi Eclipse 95-99 M/T Only
These mounts help to reduce engine movement and all but eliminate all wheel hop.
Selected options:
Color Selection: Black : 13-1901-BL
$ 72.95 x = $ 72.95
Ships in 24 hours
Manley Performance Valve Locks : Mitsubishi Eclipse 90-99 Manley Performance Valve Locks : Mitsubishi Eclipse 90-99
Part # MAN-13016-16
$ 62.90 x = $ 62.90
Ships in 24 hours
Main Bearing Cap Alignment Dowel (MBCAD) Kit : Mitsubishi Eclipse 90-99 Main Bearing Cap Alignment Dowel (MBCAD) Kit : Mitsubishi Eclipse 90-99
The bearing cap on Mitsubishi 4G63 motors is held on by studs or bolts that penetrate through holes in the bearing cap. Those holes are mach...
$ 59.00 x = $ 59.00
Let me know if you see anything I missed / or could be better
before you order your HG, have the thickness of you head measured, after it is rebuilt, so you will know what thickness HG to order,
I would let the machine shop get the guides (if needed) that way if you need +.002 guides they will know
since your getting new valves, you may as well get the +1mm
I have installed many sets of the BC springs and not had complaints about them.
I would get diffrent valve stem seal, makee sure they are Viton "Blue" seals they handle the higher temps
I am on a friends computer right now, but if you look through my posts "How to" guide work, surfacing a head for MLS HG, Oil Mod #1
It will give you an idea of what your looking to have done from your head.
if the machine shop you go to uses stones to grind valve seats and/or a belt surfacer to flatten a head, I would recomend you find a diffrent machine shop.
That equipment may be good for an old school chevy, but will not be good for you 4G63
    • frosh29
    • The_Partout_Spot
    • The_Partout_Spot
  • For sale Garage clean out
    • 92GSXtacy
