Gauge cluster problems no tach ?
chanley talon
773
14
Nov 10, 2005
Spencer, Indiana
Well im working on my brother in laws car . Hes having some strange electrical problems and i need some help. The guage cluster no matter if you swap it or not . The tachometer is not working? Also The lights for the cluster wont work ? There has been a issue also with the fuse under the hood that runs the taillights and something called fuex? It keeps blowing the 10 amp fuse. So i have no idea how to fix this but if you have any suggestions please let me know. Or if you know of any links i would greatly appreaciate it.
Check for a bad relay... Bad relays often cause fuses to blow prematurely.
EDIT: and don't bump your damn threads...
