BLACK'98DSM
Moderator
- 5,491
- 3,001
- Feb 9, 2019
Alabama
Alright my fellow DSM racers. I'm needing advice from the experienced. I need to find some ways to improve the rear traction of my 2g. I think the main problem I have is lacking any weight in the rear of the vehicle. It is fully stripped. Bare hatch, bare trunk space and Archer Fab spare delete panel. Here's what I've done so far:
- Megan Racing traction bar.
- DC Sports upper strut bar.
- All polyurethane bushings.
- 225/50r16 Kumho Ecsta 730 tires (@30 psi)
- Koni Yellows
- Megan Racing lowering springs (have also tried Ground Control and Ebay brands but these feel the best while cornering)
Even with all this I find myself having to countersteer during high speed cornering because the rear end slides around. What other upgrades should I do? I've looked into fitting wider tires but will need wider rims for anything larger than a 235. I can probably get away with slightly lowering the tire pressure as well. Anything else besides that? Maybe a tubular rear subframe? I've seen photos of autocross DSM's cornering so hard that a rear wheel lifts from the ground. I can never seem to get enough traction to achieve this. Any tips or suggestions are greatly appreciated. I really don't want to add any weight if I can avoid it. I thought about sandbagging it for experimental purposes but the added weight will cause other performance losses.
- Koni Yellows
