Fwd only 60ft times and setups
I made custom solid welded motor mounts for my FWD 2G....
I did the driver side, cross member, rear, and tranny mount.
Im powered by a GT35R and I do not spin from a 1st gear roll @14-15psi:thumb:
I get 0 wheel hop when I launch it, it still spins but hooks MUCH sooner
you can hardly tell the difference of vibration between the solid mounts and Prothanes
Heres some Pix
Driver Side
Rear Mount
Cross member
I do not have pix of tranny mount yet
I left the rubber bushings inside so0o that I would not lose the position of the center shaft....I also left the rubber bushings in to absorb some of the energy
By the way the driver side and tranny mount are Aluminum
If anyone is interested in these PM me...I will make them....also mine are rough and ugly...I did 0 work to clean them up...i can have them sand blasted
I have not been to the track yet because I am waiting on my slicks....but I will keep everyone posted...lemme kno what yall think
Thanks for the Space
That is a good idea and all, but I am not sure how long I can trust something like that. We came up with that idea about a month or two back to do pretty much exactly what you did to your mounts. Like I said, we just could not trust something like that for a lengthy period.
So this was our solution. We have only done the front and rear mounts on our 89 mirage and 89 colt.
Wow those mf'rs are going to rattle. I have the front solid mount from howell and it rattles pretty bad as it is.
2.1 60ft
stock suspension
stock clutch at 3500slip/drop.
16 psi
kumho escta asx 225/50/16 aired down to about 15lbs.
track was nice and sticky so I consider myself lucky top end of 1st and 2nd started to spin a little
homemade urethane front motor mount
These inserts are pressed in. I would trust these over a weld on a FWD car any day.
These mounts are specific to the C52, C53, C62 and C63. The bushings may be the same, but the actualy mounts is specific to 1.6L and 1.5L cars.
The inserts measure 3 1/8" for the front insert and a slight bit over 2 1/2" for the rear. I mean just a hair.
These are solid aluminum. These bad boys only cost $40 for the set. We are hacing two more sets made for some friends.
Steven
1.752 60ft with Evo16g, gutted interior, fmic, 550cc's, gm maft, 8.5/23.0-15 slicks.
Currently upgrading...should be done sometime this month.
Damn, and I thought my 1.85 was awesome on a stock tranny! nice job.
stock motor
8-9 psi
fmic
225/45/17 street tires at 22 psi
with a 2.4 60 ft i ran a 9.0 at 78 in the 1/8 mile
2.365, 60 foot
N/T, gutted to around 2200 lbs, g-force drag radials, 2600 act six puck, chopped stock front springs.
Slipped clutch at 3400 rpm's.
Also had a good driver!
AGX's (softest in front, hardest in back)) with Tiens on front (stock back)
ERT LSD
2500 lb (without driver)
24.5 x 8 slicks
slip launch (VW pressure plate, Dodge turbo disc, Neon flywheel) @ 4700
No turbo and no spray
Can't seem to get better than 1.9
MB
Update a little more power and a little less weight . Getting mid 1.8's (best of 1.855)
MB
