Fwd axle in Awd
Loewen21
211
Jul 24, 2006
Steinbach, MB, Canada
Hey guys just wondering if an axle from a 91 fwd talon will work in my awd 92 laser. Pretty much the only option i have to go with right now so if it might take a little bit of time and effort to make it work im fine with that. Thanks in advance.
I was under the impression that AWD had equal length axles where as FWD has a long axle, and a stubby axle. If you havent already done this go do this...take a visual inspection of the axle you want to replace, and the axle you want to replace it with. If they are different length's then problem solved, and just fork up the cash for the $40 axle from autozone.
Ok after re-reading my post i realised it might be a little bit confusing. The axle in question is the front passenger side axle. I was under the impression that they were the same length but maybe slightly different in diameter. Anyone?
Alright well i found one for a good price for an awd instead, courtesy of JNZ tuning. Thanks anyways thou!
