Fuel rain an fitting sizes
Guilty1s
123
5
Dec 7, 2010
Knoxville, Tennessee
I have purchased an FIC fuel rail. The female fittings into each ends of the fuel rail are 8an. Currently there is a -10 and a -6 an adaptor on each end that can be used for inlet or outlet.
Now, i plan on doing a -6 an inline fuel filter and take -6 lines to the rail, The AFPR is also -6.
Now, it make sense to me that i just run -6 lines and fitting all thoughout and just adapt the larger bore at the fuel rail from 6 in to 8 the back to 6 out and continue 6 thoughout.
I am hoping i am just misled by the larger and stagard sizes they offer, but my question is; is there any benifit/purpose to a larger hose on either side of the fuel rail.
This is just on a mild fuel system, walbro 255, lines, 650cc, AFPR and the rail, just supporting maybe 320 on a EVO316g.
IIRC you wouldnt even need upgraded fuel lines for that small of a demand for fuel. If you are going to be using E85+ or trying to support higher numbers then upgrade. Also as Brian said, the stock fuel rail will support anything you can throw at it until your considering what, 700+hp.
i actually picked up the fuel rail cause it was actually cheaper used then picking up the infamously not so great fuel rail adaptors. Puts a nice bling factor in too.
Now i dont see a reason to upgrade to e85 yet, but its been on the backburner with the switch off as an idea.
Thanks for the replies. I just look at this -10 why this huge and what the heck is used to keep pressure on a hose that large..
