Fuel rail
ohsofast122
67
51
May 18, 2012
Fayetteville, North Carolina
Does anybody know of a company that makes/ sells 8 injector fuel rails? looking at running 12 injectors next year.
So just like bastarddsm said, I'll end up cutting the current bungs on the underside of the manifold off and install smaller dual bungs. I'm currently running 8 injectors.
Didn't mean to speak for you, but I had seen it on the face.
Why did you do the secondaries on the bottom? I've been on 8 injectors since about 2010, I've always had them on the top, right behind the primarys. However, I'm wondering if there isn't a better spot for them that, and my location is the cause of my lack luster power production.
I think the location on the bottom of the manifold was due to the fabricator. I had the direct port nitrous kit installed so he decided to add the injectors to the bottom side. I might change things up and move the nitrous to the bottom and add the injectors to the top since I will have more to check. I never had a problem with the injectors being on the bottom of the manifold though. I was hoping to buy a new manifold to try this on but I've been buying things to lighten up the car.
That's a lot of fuel. 8x2150's wouldn't be enough for you?
It probably could but I want to take probably out of the equation. I would rather have more than enough fuel than not have enough. I'll push anything to the limits but injectors not so much. Plus, I don't want to deal with trying to sell my current injectors and buy new ones. Trying to sell things now is like getting kicked in the twins. :)
Well things are coming along nicely. Almost scored a good deal on a magnus cast intake but I was on the road and wasn't able to seal the deal. Moved the direct port nitrous to the bottom of the manifold and moved the 2nd fuel rail up to the top. Once it's all finished i'll send the fuel rail and manifold off to get coated.
This is crazy.
Did the rail come with bungs for the manifold side, or did you have to custom make them?
This is crazy.
The rail didn't come with bungs for the manifold. It took a little bit of searching but I found some online that were the size I needed.
