fuel questions
josh38127
611
Oct 2, 2009
Memphis, Tennessee
I just got my car running AGAIN. When I drive it won't rev above 3500. When I am parked it rev just fine. However if I stall it up to 2000 then rev it a 4 inch flame will shoot out the tailpipe. I drove for 3 miles and it turned my tailpipe gold. Is this fuel cut? The car stock. I also have hacked the air can,but the lower honeycomb not removed.:|
I'll describe fuel cut for you.
The ECU will see knock, attempt to pull timing so it doesn't knock, if that doessn't work than the ECU will cut signal to the injectors. And since even when you are decelerating with foot off the pedal, there is still an explosion in the chamber, it gives a new feeling from the INTENSE compression braking. it's almost like hitting a brick wall.
If you're backfiring, I would thing your timing is off.
Fuel cut has nothing to do with knock or timing. It is simply the ECU cutting the signal to the injectors when it sees more air entering the engine (via the MAF) than it is programmed to handle.
http://www.dsmtuners.com/forums/frequently-answered-dsm-questions/186971-what-fuel-cut.html
DSM's and Fuel Cut
Ok. thanks.. If my timing is off can that cause the black dust to appear on the inside of my tailpipe
____________________________
Craig
how can I fix this
Craig
how can I fix this
Updated my post with some links that may help you ^^^
Its just like dust.. But it doesn't smoke ( Actually its like soot from a chimney)
never mind i see them
Thank Calen.. I read it I now what is going on and I bet I can get her fixed.;)
