2G Fuel Pump Issues
Ferp
159
14
Sep 14, 2014
Edmonton, Alaska
My fuel pump died yesterday and I put a new one in today. It isn't coming on though. I can't hear it humming and the car wont start still. I checked the pump to make sure I had everything put back together correctly and it all checks out.
Check the wires on the sender itself grounds and the power wires, I had a bad ground no start, fixed the ground boom pump works with link to turn off and on. Is it rewired check all the connectors at the relay and the fuse near the battery if you have it rewired, also check the fuel pump relay.
Check all your fuses. Could have been fuses the whole time.
