Tyeler18
- 2,568
- 368
- Dec 16, 2008
Casa Grande,
Arizona
Yes, that's why you need to test it.
It was, if you have strong vacuum at the AFPR but it still wont drop pressure- the AFPR is bad. If you don't have vacuum obviously theres an issue with your t-junction or hose.My apologies, I thought your comment was referring to the afpr when you stated "then it's bad"
UPDATE: I've been working a lot so haven't had too much time to give my car. Last night when I got home I had about 15 minutes so I started the car, took off the vacuum line at the Tee of the boost source. Instantly I felt vacuum from the T and so I capped it with my finger. I then just sucked some air through the vacuum line going to the afpr and also blew air into it both as hard as I could. The AFPR gauge dropped like 2-3 psi when I sucked on it and went up like 2-3 psi when I blew on it. Should I have been able to get more than this just using my mouth?
No fuel in the vacuum line either. I guess this is kinda' good news? It should mean my afpr isn't bad. I just wonder why it's not dropping as much as it should.. sadly, that's all I had time for so my next step will be to replace that line from the afpr completely. Would it be wise to just use a vac line to a dedicated source on the nipple from the intake manifold instead of the T into the boost source?
Also, upon some further research, I THINK that maybe a restriction in my fuel return could be the only other thing causing this. Any other suggestions?
Sorry for the slow progress, but I try to do what I can whenever I have a free window.
Sounds like it's working. Run a dedicated NEW vacuum line and see what it does.
Also a restricted return line would prevent you from lowering pressure below your current base pressure which you mentioned being able to do.
