ECMlink Fuel Pressure Sensor wiring
Barra
7
Apr 4, 2003
Salem, Oregon
I'm looking at old threads on this topic but still am uncertain about getting a good 5v source for the sensor. I have the cheapo made in china 0-100 psi ebay sensor. Car is running V3 with 2g MAS. At this time I think my only available input is the EGT which is logging my WB now. I plan to swap the WB for the FPS for those times I want to log fuel pressure.
I have a federal car but I'm wondering if the wiring harness has the plug for the EGT? There are a number of plugs on the harness but I'm not sure if any are for the unused EGT on the federal cars. Even if there is one, would it be a viable option for connecting the FPS? I looked at some wiring diagrams online and it looks like the EGT on the CA cars only gets 4.7v so it may not be enough (range on the china probe is supposed to be 0.5-4.5V). However, if it would work it seems convenient to just fab up a connector plug and just plug the FPS sensor directly to the harness when needed for logging.
Has this been considered or tried in the past?
Can I just tap directly to the TPS wire without affecting TPS function? I read on a prior thread that taping into the MAS sensor 5V wouldn't work.
I've tapped into many different 5v sources and I can't think of any that didn't work. I can't remember how my fps is hooked up but it's spliced into a two way switch with my wideband, and I just switch between inputs as needed.
I was referencing a thread from last month on the same subject here: https://www.dsmtuners.com/threads/resolved-help-wire-up-a-fuel-pressure-sensor.516386/
I'd rather use the MAS 5v if it's all the same, I already have cut into that harness to wire my 2G MAS. I figure I can just splice of the the green red 5V to the sensor power and then splice back in the green black wire for the sensor ground. After that the signal wire for the sensor to a switch like you or a connector swap between the WB and this into the EGR temp input.
  • Wanted 95 eprom
    Looking for 95 eorom
    • GhostTypeP0300
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
