Fuel pressure gauge
mitsuclipsegsx
2,561
8
Apr 5, 2004
Dover plains, New York
i am buying a fuel pressure gauge from summit and their 2 to choose from what should i get?
1. Fuel pressure 0-15 psi(outside mount)
2. Fuel pressure 0-100 psi (outside mount)
thanks
L2RTSiAWD said:
Get a 0-100 PSI electric inside one.
If you want to spend $150+....
The cabin-mount FP gauges are nice to have since you can see if you're losing fuel pressure while you're driving, but it's not a necessity.
0-100PSI engine-bay mounted is what I have.
0-15PSI is for carbureted cars.
mitsuclipsegsx said:
so whats wrong w/ the first one 0-100 psi like u said will it work though??
Nothing. As long as it's a liquid filled gauge, it'll work just fine with an AFPR for setting your base fuel pressure.
one more ques see i had bought a oil pressure gauge and i called the place i am taking it to, pruven and they said they can't install because its mechinal and i called summit i not paying 190 for a fuel gauge :thumbdown now i already asked pruven about trans temp gauge they say they never installed one before, so i found in mag a water temp gauge electrical now will i have any probelms w/ this one will it work fine casue its electrical and not mechanical??
Any oil,fuel,or water gauges that mount in car need to be electrical because you don't want to to run lines to the cabin, that's why they are way more expensive.
i dont mean to boost up this thrrad but i need to know tonight casue i gotta order it tonight
thanks
Yeah, water temp isn't that hard to do as electric since it's easy to convert degrees to an electric resistance.
Pressure is a bit harder to do, so they cost more.
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
