Fuel pressure gauge question
apedog
158
May 6, 2009
Lewisberry, Pennsylvania
So I bought an SX fpr but didnt realize that there isnt tap on the regulator for a gauge. Is there any other way to read fuel pressure? I have an 1/8th gauge made to fit an fpr but I cant use it
You could run a T adapter on the rail side of it, not the most ideal way to do it though.
You can find AN fittings that have 1/8" NPT ports in them. Examples.
Ahh this is exactly what I need. Thanks:D
Can you point me in the right direction to where I can find one?
All depends on what fitting you want. The black one I actually found on eBay. Try searching for "AN fitting with 1/8" NPT port" or something similar. Then you can add male/female and AN sizing to try and narrow it down.
You can also get an AN to NPT reducer to replace the plug in the one side of the AFPR. Then you can get a 90° NPT fitting to make the gauge readable.
There's a variety of options. All depends on what you want.
