ECMlink Fuel Map tuning help!
614talon90
Jul 11, 2012
Grove city, Ohio
So I do not have a ton of experience using Dsmlink, but do have a basic understanding of it. In the past I have used ECU Flash to tune my evo 8 with some success. Anyways my problem is this. I bought my talon with it already converted to speed density but not tuned all that well. Ive got the global fuel settings and the deadtimes all worked out and just cruising around the car runs perfect. But when I go WOT and start to get into boost things arent right. At first itll start to go rich like it should, running around 11.5 and tappering down to 10.5 at lower boost. But as the rpms increase and the boost increases it starts to lean out..ALOT. Itll shoot up to as high as 16.5 when its up to full boost. I logged it coming home today under only half throttle to see what it was reading and according to the load factor and the rpms in comparison to the Openloop fuel map it should have been running nice and rich. But that was not the case. The fuel sliders are all zeroed out because i wanted to avoid using them. I just can not seem to figure out what is causing this. And advice would be greatly appriciated.
Sorry I thought i had to keep it in the newb forum, I will also post a log.
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
