fuel line question
mattgbade
Aug 10, 2013
ridgeland, South Carolina
So i bought the magnus fuel rail for my dsm and was wanting to replace the lines from the tank to the filter and to the rail i found the kit from SIM but it has a 6An line and the rail as a 10An inlet where could i get the adapter to make this work or should i use another setup? The mods about to go on my car with this is a mhi 20g with 10cm compressor externaly gated, precision 850cc injectors, 255lph walboro fuel pump, GM 3" MAF, DSM link v2 any suggestion or any twerks to my setup would be greatly appreciated thanks!
I'm sure Jegs or Summit would sell -6an to -10an adapters. But the Magnus rail is massive overkill for your goals.
Well the main reason is one of my fuel lines is rusting so i want to replace it.....and the reason for the bigger fuel rail now is because i got it on deal and already have in the works a g4cs build with a 4g63 head with complete gsc power division valve train and 272 cams. And i also have a 6 bolt 2.3 stroker short block i built a month ago that i was gonna use that gsc head on but decided on the g4cs but for both the builds to work i need to beef up the tranny and axles to benifit and a couple other things i just need to take my stock turbo off to put on another eclipse and im just trying to make sure i have everything before i start the 20g swap. Plus my buddy has a subie thats needs its ass cut cause he keeps talkin LOL....Yes right now the rail and lines are over kill but will benifit later plus thats what a regualtor is for LOL...
Just completed the swap took me 3 days on the ground defently wasnt as hard as i thought thanks for the right up!
