2G Fuel injector swap - clearance issues
dsmlivesmatter
51
10
Mar 31, 2019
hamburg, New York
I'm trying to install FIC 1200 hi z injectors that are supposedly a bolt on easy affair..... my problem is the connector where you plug in the injectors are lower on the FICs and causing them to hit the head and not fit correctly.. having a hard time describing my issue I'll try and take some pictures. The stock injector next to it has a nice space in between the connector and the head, the fic injectors connector is hitting the head and not seating the lower seal. Maybe I'm just not seeing the problem any help is appreciated
You can spin the injector so that the clip is away from the head and then connect it. That’s how I have my injectors.
Thanks guys, that's what I ended up doing. I just was pretty sure that I was doing something wrong LOL all my injectors are pointing towards the passenger side except the one closest to the timing belt, it works and runs good with no leaks just looks funny
  • Wanted 6 bolt NT water pipe
    • chrisman287
