2G Fuel Filter Replacement on 2g Turbo
stockmkt8r
164
May 4, 2003
Anyone have instructions for replacing the fuel filter on a 2g turbo? I looked at VFAQ but didn't find anything.
Any thoughts would be appreciated! Where is the fuel filter located? Any tips to get it out? Etc.
Thanks
Follow the fuel line from the rail on the passenger side. It's a simple bolt on bolt off affair. Undo the lines before you take the filter out of the bracket. Watch the botton line. If the flare gets stuck you can accidently twist the line. Flare nut turns independently of the line. I use two wrenches to break it loose and a flare nut wrench on the...well....flare nut.
