Resolved Question on Fuel Filter Replacement on 1G.
tsi1991awd
1,366
6
Sep 28, 2008
Puyallup, Washington
I searched and couldn't find the answer to this....I know the top banjo bolt on the fuel filter is a 19mm. Is the bottom a 19mm as well?
I can't even see the bottom bolt, which makes this a bit difficult...
Also, what size is the nut on the fuel filter that you put a wrench on to counter with? And is it the same size on the bottom?
There isn't a fuse that I know of. When I changed my fuel filter I didn't unplug the pump or anything, you won't lose much gas, it probably wouldn't hardly amount to anything.
Sooo after a few minutes of searching for it, its the MPI fuse.....so why are you going to say "wow" like I'm a dumbass?
Well I just unplugged the fuel pump in the trunk anyways. No big man.
But anyways, I don't know what the fuss is about the fuel pump. For some reason the 14mm flare nut wrench I had did NOT fit. Maybe I got a defective tool or something. But I used a regular 14mm wrench and it came right off. I sprayed PB Blaster on it the bolt/nut and let it soak and then again maybe 5 minutes later and let it soak. Came off so easy. Wrench didn't slip or anything.
Saw a great performance gain after the filter change...even though the old filter didn't seem that dirty. No brown gas or anything.
Could of been clogged.
That's what I was thinking. Clogged but didn't have any brown gas or anything. Was clear, and when I ran water through it, everything was clear. I say it was clogged and with the new filter, it can flow freely. Because man, does it haul ass now!
O hell yeah, clean fuel, air, oil, and good spark works wonder.
19mm banjo bolt on top, 14mm on bottom (use line wrench, do not loosen the larger nut) 12mm to attach to firewall bracket, 8mm to loosen clamp around filter
