2GFWDbeast
- 1,094
- 15
- Jan 17, 2010
kenosha,
Wisconsin
i have been having this problem for the last 6 months now. And iv already gone thou 3 battery's. The last battery i bought was about 1 1/2 months ago. Today the car started up no problem. Then no more then 5 minutes the car acted like the battery was almost dead. The only thing i did was take my chip out of my ecu and put in my ecmlink chip.
So i bought a test light and read the tutorial on how to find a short or battery draw. So with the test light hooked up i started pulling relays and fuses, because the test light had a bright light on.
I came across the 40A bat fuse pulled it light turned off. Put it bad in then i pulled the 80A ALT fuse the light turn off on that one to. Finally pulled the 30A belt/ ceintures and the light turned off on that one also.
SO does Does this mean i have 3 places that is draining my battery causing the cells to die in the battery. I'm completely lost. Please help!! The last 2 battery's i replaced had a bad cell.
