front mount help
youl need to customize the piping. i would just get alot of 90 degree and 45 degree bends and some stright pipe and figure out how to run it then i would weld the pieces together.
ok thanxs
any ideahs on mounting it? im kinda confused by the design if u can see the pics of it
more or less ul have to shave some of your front bumper off using a dremel or any cutting tool. to mount it get pipe hangers you can find these in the plumbing section in hardware stores, get 2 straps and 4 sheet metal screws and screw 2 into the FMIC one on each strap and the other two mostly onto your radiator mounts.
