FP3052+tubular manifold+Tial 44mm WG will they bolt up?
dalatinromeo
889
26
Nov 18, 2004
Fair Lawn, New Jersey
Ok after searching on here, and on FP's website I see that the FP 3052 uses a Tial 44 mm external WG. I am ordering my turbo-back exhaust next week :D , and at the same time might purchase an exhaust manifold. I choose to get the DNP's SS tubular exhaust manifold. I was just curious will the WG off the FP 3052 clear the tubular manifold? I shouldn't encounter any problems with the WG coming in contacting with the tubular manifold right?
Personally, if you're getting the 44mm tial already, get the vband version that clamps to the fp housing. I don't really see any reason to hang the WG off the manifold when you have that option.
If you really *need* a new manifold, i'd just get an Evo3 and get it ported to hell.
All 44m come with Vband.
My friend have one (fp3052/tial 44) and he clear your manifold with no problem.
AL
The manifold he is getting doesn't have a wastegate flange.
1990EclipseGSX said:
I run this exact setup and everything fits without a problem. Absolutely no clearance issues.
Chris
thanks :thumb: what spring pressure did you order the tial WG? i was thinking of ordering it with the pressure at 1.4 bar(20.30 psi) then just increasing it using my boost controller.
smack me sideways, i guess i should read things more closely. :p I didn't scroll all the way down on those manifolds.
Should work great. Here's a picture of a friends car (NDgsx)... He's running a 40mm (non-vband), that same DNP, and i think a 3052 in this picture. He's now running a 3575. OMG
Just keep in mind, you can never run lower than the rating of the spring. I'm sure you know that already, and I'm sure you wouldn't be buying a 3052 and run less than 20 psi anyway, but I just thought I'd point that out. ;)
This set-up that you have picked out is the exact same set-up I'm switching to this winter. fp3052, 44mm Tial, DNP...... I just have to wait until my 6-bolt is built and in the car first. :thumb:
Staytuned said:
Looking at the pics and based on the fact that I have both the FP 3052 and the 44mm wastegate you should be alright.
Steve - Where do you see full spool at on the fp3052?
I went with the 1 bar spring. I figured 14.7 psi would be a good place to get a base tune without blowing anything up. Also, I drive a 30 mile mountain pass/canyon daily, so it is nice to be able to have a 17 psi program to commute on. That is just me though. As long as you can get good gas, you should be fine with a 1.4 bar spring.
Chris
