FP DSM turbo question
alright thanks man. I was jw because I read on here somewhere that putting a oldschool red hotside on a green xl was a upgrade. but that didn't make any sense to me because I was pretty positive that they were all 8cm housings
The Green XL uses a 65MM turbine the OS Red/Red/Black use a 67MM turbine. The term 8CM refers to the A/R of the turbine housing it doesn't reference the contour, inlet, or outlet.
Putting a 67MM Turbine housing on a 65MM turbine is an upgrade as much as putting a hole in your block is an upgrade.
-Michael
