FP 68HTA compressor map?
Can you give me an idea of what the range is for optimal efficiency (both pressure and air flow rate)? I know they claim 47lb/min but it sounds like that is pushing the turbo as hard as it can go, mostly likely not the optimal range.
Expect to make like 20 more horsepower then the evo3 16g.They are about the same turbo I was going over infomation about it at a local shop.So best would to try to match up what info you can find on a evo3 16g and just bump it up a little for the hta68.Thats the best advice I can give you.:thumb:
