fp 68hta Turbo
2GKiller03
May 12, 2010
Portland, Oregon
Does it directly bolt up to 2g?
Nothing extra needed?
Does anyone personally know if its a good turbo or not?
did you use the search function and look around for your answers first?
but to answer your questions
yes.
yes.
don't know personally...
technically yes it will "bolt up" to a 2G, it comes with a DSM turbine housing however...
you will need the basically the same install kit as doing a 16G, new oil feed lines, J-pipe, etc. etc...
as to whether or not it is a good turbo i cannot answer that personally, there are a few people using it and they all seem to be putting out a good amount of power but everyone has their own preference in what they like.
fast spool and sounds mean when it is spooling. I should be going to the dyno sometime this week to get some numbers for this turbo. I will be running about 26 psi of boost with about 15* of timing on e-85. yes I know 15* is low but I wanted to start low and work my way up to about 20*
