2G Forced Four 100.1 shift box install
max_effort_tsi
Supporting Member
12
18
Oct 15, 2021
Paso Robles, California
I am no longer using the factory TCU. Almost all the information is referenced from Forced Four’s website. I decided to do a write up that was a little more straight forward and accurate to the 2g. This is just a basic set up that worked for me. If I end up finding anything wrong or changing anything major I will update the thread. If anyone sees any mistakes please let me know or if you have anything to add please do.
8 pin connector from 100.1 shift box to 26 pin TCU connector
-Yellow wire to Solenoid A pin 12 (Grey wire)
-White w/ Black stripe- unused in my car
-Brown wire to shift Solenoid B pin 25 (Orange wire)
-Black wire to Chassis Ground
-Green wire goes to Lockup Solenoid pin 13 (Red Wire)
-Red wires (power wires)-wire both power wires to both TCU power wires pin 2 & 15- (Blue w/ Red stripe)
-Blue wire to Pressure Control Solenoid pin 26 (Blue w/ Yellow stripe)
10 pin connector from 100.1 shift box to 16 pin TCU connector
-Green wire to Throttle Position Sensor pin 19 (Brown w/ red stripe ON 26 PIN TCU CONNECTOR)
-White w/ Green stripe- unused in my car
-Purple Wire to Up-shift wire (Blue on Evo X paddles)
-White w/ Purple stripe to Down-shift wire (Yellow on Evo X paddles)
-Grey wire to brake switch -unused in my car
-White w/ Grey stripe- toggle switch (Auto/Manual Mode)- unused in my car
-White w/ Blue stripe to Overdrive Off Switch Pin 2 (Red w/ Yellow stripe)
-Pink wire to Speed signal pin 15(Yellow w/ White stripe)
-White wire to Engine RPM pin 9 (White wire)
From Evo X paddles
-Ground the Green wire on Evo X paddles
Check your wires if you are using Evo X paddle shifters to verify your up/down shift wires & your ground wire. The wire that goes to both up/down shift wires gets grounded.
Not Evo padels but push buttons.
This is how I got it mounted up. Not the way I want it but it works for now. I had to cut up and shave the Evo paddles a good bit to fit inside the factory steering column. They line up almost perfectly to fit the 2g, but I’m unsure how it fits in the 1g.
I have thought about doing something like this but I really dont want curly cords. For now I have 3d printed a button box that goes where the coin holder is beside the eco button. It works but I'd rather paddles.
The cords can and do get tangled in the column.
Yes I just cut and spliced them in and used butt connectors. Unfortunately, I don’t have any other pictures. What wires are you referring to?
1 plug is for the power and ground for the unit.
1 plug is for all of the inputs that you need, VSS, RPM, TPS.
1 plug is for outputs to the solenoids in the transmission.
It's just a lot of wires and all of the needed ones are in a auto car already. In a stick car converted to auto, you will have to run your own. It looks intimidating, but it's just 1 wire at a time and not hard. :thumb:
All wires in general. The install looks a bit intimidating LOL
Intimidating for sure but actually pretty simple and straight forward once you get into it. As long as you follow my initial post with the pin number/color wires you’ll be alright. Take your time, check twice and cut once.
Update. It was brought to my attention that I counted the connector pin out differently than the wiring diagram on Forced Four’s website. Everything is still correct but keep that in mind.
