1G Fmic install on auto
enriquez2000
2,411
1,020
Oct 5, 2014
fort collins, Colorado
Anyone have personal experience? Looks like theres nore stuff in the way obviously.
Curious what you did with trans cooler lines and trans check stick... looks like they will be an issue.
What FMIC specifically? With the VRSF kit on my old 1G, I relocated the transcooler to the stock SMIC location's bolts, and flipped it 180*. That pulled the lines out of the way of the hole, and it helped the transcooler to fit in the passenger side foglight hole. For the transmission dipstick, I just bent it out of the way. It didn't take much bending either. It's not as bad as it seems.
It looks like a vrsf type knock off to me...
Did you use rubber lines to replace the stock atf lines?
Sounds really easy.. wasnt sure the lines would allow that without changing them.
I hope the punishment one works well. I was worried id have to buy more parts.
    • dsmmario
    • Detail
    • dsmmario
