TuskeeTuner
5+ Year Contributor
- 186
- 82
- Dec 16, 2020
Everett,
Washington
One picture there was a green valve cover - another unpainted.
That wiring harness looked like a giant mess. Do you have any check engine lights? Do you have any electrical problems?
Did you install the ECMLink software onto your laptop? It comes on a CD or maybe a download. The factory injectors require a resistor box otherwise the ECU will "burn up."
Like the Wiseman said; you need to figure out EVERYTHING and ANYTHING that's installed onto that car. Pull wiring diagrams, Haynes manual, anything you can find about how these cars work. You can have lots of "discussions" here, and get a few useful fill-in-the-blanks, but you're gonna have to make all the discoveries.
The guy you bought the car from could have started out with a perfectly running car and then butchered it.
Unless you have an adjustable FPR and fuel pressure gauge, the fuel pump isn't that critical right now.
Does the T28 come with a "stock-looking" compressor cover like a 68HTA or Bastard 20G? Some turbos on these cars can appear stock, but you might not know unless you either drive the car, or pull the intake pipe and look at the compressor wheel.A stock onealso the turbo from what I can tell is stock also.
I don't understand...it cranks but "wants" to start? And fails?So I swapped the plugs and made the changes in DSM Link it cranks and wants to start but doesn’t…
As for the config.
It’s just the non-95/96 CAS in the MISC on DSM link and swapping plugs to 3-2-1-4 correct?
That wiring looks like a rat's nest. These cars are 100% intolerant of wiring errors.Here ya go boss
