ECMlink First idle log, please check it
Black_Raven
Jan 12, 2006
Ebersbach, Europe
1). Any boost, vac, or exhaust leaks?
No
Boost leak tested 5psi above your max boost with no leaks?
Yes, (i dont drive, test until 17psi)
2). Verified mechanical timing?
Yes
3). Verified base timing?
Yes
4). Ignition system
COP or Stock Coil: Stock
Wire brand and Age: Magnacore/5 year
Spark Plug brand, type and Gap: NGK-BPR8ES/.021
5). Motor health (Compression Test)
n/a
6). Performed basic throttle body adjustments?
Idle Switch: Yes
Throttle Cable: Yes
TPS: Yes
BISS: Yes
7). Compression ratio
8.8:1
8). Any known bad sensors or brittle wiring?
No
9). Any DTC/CEL codes?
No
10). Electrical system
Car off (not running): 12.4 volts
Car running: 14.4 volts
11). Base fuel pressure and injector values
Base Fuel Pressure: 43.7
Injector Size (cc/min): 1200
12). Properly calibrated and configured wideband sensor
Sensor Brand: LC2
Calibration Date: 2019
13). Type of fuel
Type: 91 Octane
Percent of Ethanol: 5%
14). Watched ECMlink how-to videos?
Yes
Hi guys,
I'm just starting to tune my vehicle with DSMLINK.
It starts with idle, I have 2 - 3 questions.
Short details about my car:
99er Eclipse
2.3 6 bolt
70mm S90 Throttle
1200 PTE Injectors
1g CAS (green)
JMF Race Manifold
LC2 Wideband Sensor
3.5 Bar AEM / AEM IAT (Speed density)
I use the instructions "How to Tune a 1G V3 SD ECM LINK with no MAF
Version - 1.5 By Aaron Ruppert AKA Dr Turbo".
1. Log (cold-idle)
The vehicle is cold and running at idle up to operating temperature.
2. Log (idle-warm)
Continuation of Log 1
3. Log (hot-start1)
I restarted the vehicle. The idle speed goes to 2500 rpm for a few seconds, i dont no why?
4. Log (idle-warm2)
The values AirflowPerRev, STFT, LTFT and ISC Position look good.
5. Log (hot-start2-idle-warm3)
I start the vehicle again for the second time. Again, the revs are for few seconds high?
My questions are:
1. Why are the rpm so high (~2500 rpm) after starting the warm engine?
2. Do the logs look okay to you? The ISC position is only close to 30 in the last log.
I checked the ISC valve, it's fine.
3. The idle speed fluctuates a little bit. I have FP4 Camshafts and 1200 PTE injectors.
Are those fluctuations normal?
The car has not yet driven with this ECU.
I want to make sure the values are okay.
Thank you all.
Pierre
Did you adjust the biss with the car running? I think 1g is different but you do it during warm idle in neutral for a 2g.
also with idle set to 900rpm you may have to retard timing
ecmtuning.com/wiki/idlesurge
