check my idle please *log inside*
turbo98eclipse
1,096
15
Jul 27, 2004
northern, New Jersey
im still not sure why my WB is reading so lean-- i put the est AF ratio on link and it appears fine..
i went for a 10 min cruise with a 5min idle afterwards. im running SD so i did the SD ratio + SD combinedFT and everything seems to be ok... is there anything else i can do manually to fine tune? im still not too sure how to "work" the SD table
any advice would be appreciated-- thanx
(i can also add the 10min cruise log if anyone needed to see that)
