1999 Mitsubishi Eclipse N/T Vehicle Profile & Build Thread
Black_Raven's Eclipse Europe N/T (turbo, awd)
Ownership Status
Currently Own
Turbo Type
GT30 Variant
Drivetrain
AWD
Build Type
  1. Street
4g63 6 bolt swap, Gates Racing Performance belts, JMF Intage Manifold ( Race )
1200 PTE injectors, 225 Walbro hp Fuel pump, A1000 Fuel pump, fuel catch tank, Custom FMIC,
2x EVO XIII BOV, 3.5" Custom Downpipe and Cat Back, eleminate EGR, FP Aluminum Intake, K&N Open filter, FP Exhaust Manifold, GTX30 Gen2 (FP Hosing), Tail 44mm Wastegate, oilcatcher, setrab oilcooler, Koyo Radiator , 2 SPAL fans, Supersport S90 70 mm throttle, Fuelap fuel pressure, SlowBoy fuel rail
Mods-Engine
Manley H Beam rods, Wiseco Heavy Duty Stroker pistons ( 8.8 : 1 ), Eagle 100mm Stroke crankshaft, ACL Tri Metal Race bearings, ARP L19 head stuts, FP4 Camshafts, Arospeed Adjustable Cam Gears, kiggly main girdle, Supertech High Performance intake valve (1.00 mm oversize )
Supertech High Performance Inconnel exhaust valve (1.00 mm oversize)
Mods-EMS & Logging
DSMLink v3 SD, D1 Spec Distinct Fuel / Boost / Oil Temp gauge
Mods-Drivetrain
AWD, evo 9rs LSD rear, ACT 2600 Extreme 6 paddle Sinter clutch, Fidanza Flywheel, evo3 gear set
EVO 8 Brake, TEIN SS suspension, Team Dynamics Pro Race 1.2 wheels (8x 18) with Pirelli Tires (225/40 R18 ZR), evo 7 steering wheel
