first dsm, need help please
krazn
Feb 24, 2005
Philadelphia, Pennsylvania
hi guys. i drive a 95 gsx. i've been searching on this site for awhile now...because i didn't want to ask a question that has already been answered. however, i am not finding my answers fast enough, so i hope this will help me in my quest to start my car.
here are the symptoms.
turn key to "on" position
dash board lights do not come on.
when trying to start car, car will crank and not turn over.
when i play around in the car, like jiggle key, or step on clutch numerous times, i get lucky and the lights on the dash finally come on...and the car starts.
when i drive around, i find no problem...still pulls like a champ. however, when i turn off the car.... the cycle continues
car dash lights aren't on.....
and i have to mysteriously play around in side the car for about an hour.....until i get the dash board lights back on again to drive.
from what i have read....i've seen that it could be ecu, ignition, or crank angle sensor??? i'm very confused...i dont want to fix all 3. if someone else could pin point exactly what my problem is...it would be very helpful...thank you
yeah check ur fuses and wires remove the bottom panel cover make sure no wires are loose, or damaged etc...........also whut EXACTLY do you to make the cars interior lights come on??????
:talon: monty :talon:
i did check all my wires and fuses...all seem to be good. what do i do exactly to get the interior lights on? ...i seriously do not know. right now...i am trying to get the dash lights to come back on...but no luck. i think what was holding by a string...finally died out.
i found another symptom if it helps you guys pin point my problem....
the orange light around the ignition sometimes come on...and sometimes it doesn't. when the door is open....it supposed to make a noise that reminds you that the key is in the ignition....but the noise it makes sounds very choppy...like its losing power. its not very consistent like it used to be.
ok....going back out to check connections again. thanks for input guys. but i still need more advice....
krazn
try checking ur battery terminals.......make sure the arent corroded or anything.......make sure they're on nice and tight and make sure ur battery is working properly.........next u need to REALLY check every single wire in there make sure nothing is loose or shorted anything of that sort..........go to autozone and rent a voltemeter of some sort and check the system.......just a thought
:talon: Monty :talon:
Pull the clamshell off the steering column and look for wires that have been screwed with. Sounds like something's broken or loose. Look for vampire taps. If the car was owned by a woman, and she used the usual womanly boat-anchor for a keychain, it may be a damaged ignition switch.
I hope you're still skinny, or getting under the dash is a sledride through hell.
oh my god, thanks alot for all your help guys! it was in fact a loose wire. it ended up being an alarm wire burnt up...so i fixed the connection and all is good. thank god its not something major. i was almost gonna give up on dsm...i'm glad i didn't.
  • For sale 4G63 Frontline Fabrication V2 Billet Valve Cover
    Frontline Fabrication V2 Billet Valve Cover $750 + shipping & paypal fees* swivel AN fittings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
