finished motor swap not wont start
Dsmwant2b
Jun 9, 2006
SALEM, New Hampshire
okI got spark im pretty sure i got fuel probably firing order or could he it be anything else guys i opened the ecu looks likeone of he diodes is leaking help please???
You said you were pretty sure you had fuel, did you prime the fuel system? It takes a good full minute or two of priming to actually get fuel to the combustion chamber. I've done it by unhooking the starter, but there may be a better procedure. As for the ECU if it ran before, well should be the same you'd think. Good luck!
You profile says that you have DSMLink. You can run your fuel pump with the car off through the link. Try doing that and take off the supply line to the fuel rail. If fuel comes out then you can narrow it down.
