Finding a new ECM
Yamaharyder600
140
Nov 5, 2010
Tarentum, Pennsylvania
Ok, so i have a 96 eagle talon tsi and the isc drivers have gone and the board appears to have bubbled. I have found the drivers and the capacitors I need to rebuild but I am afraid that the board is toast. Does anyone know where I can get a new ecm perferably an eprom without spending a fortune. Theres a couple on ebay but you never know what your gonna get.
Any input would be appreciated!
Thanks,
Corey
Use of a 97+ ECU will require you to swap your injector plugs and spark plug wires around to worm properly as the CAS is signal is inversed.
Check with ECMLink for ECUs and they also now convert non EPROM ECUs to EPROM.
Also I believe he would throw an emissions code due to the 97+ having and different evap system layout. Just all depends on if you have to do emissions or not
