help finding a crank
Eagle makes great products, before installing you should have all the clearances checked to make sure they are within spec and that you have no defects (this is so rare it doesn't actually worth mentioning).
Eagle makes great stuff.
i have decided to just buy an eagle 100mm instead of the machined 94 mm forged 4340 chromoly crank, is there any reason i shouldnt buy this? like depth of stroke and so on?
like how do i lower my rod ratio to avoid rod angularity and reduced rpms
:confused:
also does welding the oil squirters in the block help prevent crank walk cause these cranks arent cheap and i want it to last
a good thrust bearing, and appropriate clutch and pressure plate setup plus checking and making sure the crank end play is within spec at end of assembly is all going to be key for when you have it assembled. As far as the rods, I don't know 100 percent on that one. I'd let some of the more experienced guys fill ya in on that.
Also, I've had seven bolts with oil squirter mods done and not, I've actually never had one walk on me.
any good brands on thrust bearings i should consider?
also i saw a chart some where in a discussion that showed displacement for 4g63 block with various mm stroke lengths and cylinder bores with rod lengths anyone know where this or another similar chart is located ive looked and cant find again
im looking at buying the eagle 94mm 7bolt crank for my talon anything i should know before committing to this company and purchasing this $500 crank any car accessories input will be greatly appreciated........
:thumb:
Mostly make use of eBay and amazon for purchasing. I think you will find crank in these sites.
