2G Fill plug
JaKee003
55
Feb 4, 2017
Keller, Texas
Fill plug is stripped really bad, I bought a bolt extractor kit at autozone and didnt work. Is there another way I can take it out
Give vice grips a try, or a real bolt extractor. The kind where you have to drill a hole into the metal and hammer the extractor in to grip. I think those work better than the kind I think you used. Try the vice grips first though.
Heat, Seafoam Deep Creep and some vice grips. You could also weld a nut to it. Heat and Deep Creep will be your friend here. I all else fails, you could fill it through the Reverse sensor as stated. Just be sure you are putting in the right amount of fluid.
Those bolts are always in there very tight. None of the above will work except for welding.That head Is completely rounded off. You need to weld a nut to the top of that and use a breaker bar. Easy
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
