what is the Transfercase and Transmission Drain and fill plug size and thread pitch?
ApexVIII
812
5
Jan 12, 2008
Modesto, California
basically as the title states what is the Transmission and transfer case oil Drain/fill plug specs?
and where can i order one, i looked on ExtremePSI but found only the Oil pan plug. the nearest Mitsubishi dealer is almost 2 hours away... :(
you meam the thread sizes? that's one i haven't had to check thus far but i probably have one if you need it (used of course) from one of the trannies i went through here a few months ago when i blew mine and had to make one good one out of 3+ bad ones LOL... I have drains, and fills, and i believe that the fil for rhte t-case and trans are the same, either way i kept all those little odds and ends from the scarp cases and such just in case i ever needed them, let me know what one and shoot me 5 bucks for postage and gas to the post office and i'll shoot you over the one you need, i'll give you PP addy in PM when you hit me up
