few problems
Could this be the issue?
This is the ground wire (I think) that runs to the negative terminal on the battery. Is it normal to have random wires hanging out like that?
Alright how do I replace it and with what?
Guys I finally realized that my car runs very good most of the time but sometimes when my headlights are on the car is very non-responsive and drives like shit. Ideas?
Replace the large battery cable. For other frayed wires cut the frayed portion out and solder in another wire of the same or larger diameter (gauge) to replace the frayed section. Tape with electrical tape. [Or if you want to do it the better and proper way is to cut frayed portion out and slide heat shrink tubing onto it. Then put in new wire piece, solder, slide tubing over solder connections, and heat with hair dryer to shrink it on nice and tight (which keeps joint protected from moisture).]
If frayed at end of wire at a terminal, just cut wire and solder on a new terminal.
Replace that wire, like other have said. Thats 2 or 3 dollar wire from autozone. Take your car there have them match up wire size. This should fix your problems. Also, is your starter shimmed to the transmission. I know for 420a theres a washer[shimmey] thats bolts to the transmission on the negative cable that connects to the starter. i had a problem with my 2gnt same situation. Always needed a jump etc. Then i notice the missing washer and my negative cable was corroded.There can also be one for the 4g63 cars
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
  • For sale 1g 1G Driver & Passenger Door Jam Seals
    1G Driver & Passenger Door Jam Seals $50 + shipping & paypal fees* these are the door jam...
  • For sale 2g 1997 Mitsubishi Motors Eclipse Service Manuals
    1997 Mitsubishi Motors Service Manuals $50 for the pair + shipping & paypal fees* I priced...
