Feels like a brick wall..
t56speed
67
Oct 23, 2012
Searcy, Arkansas
OK guys I really need to get a logger bc something is up with the car. I boost leak tested the car today and found none!! Now that i put the silencer in the muffler an killed the boost creep problem the car really feels like a turd under boost and runs a 10.0 afr at wot at any rpm. I mean it feels like as soon as I go wide open it just goes into saftey mode. I mean seriously I can make the car accelerate faster with boost creep an partial throttle boost at like 10psi. wtf. :notgood: Idk what the deal is bc cruising the car does great and gets good mileage but as soon as I hit boost it goes omega rich and just black smokes like a diesel :confused:....
Would appreciate any help. Btw even put the mbc back on it and tried to up the boost a lil to help lean it out and it still just runs like crap... Makes me wonder if the knock sensor is going bad or something..... Idk what to do... Im gonna pull the silencer back out tomm so the turbo can breathe again...
What condition are your 02 sensors in? When you put your wb in what did you do with the one that was there? Or did you weld a bung on and put it in that one?
How do you know the engine is knocking?
Using the MBC to try and control AFR's is not a good idea.
How much boost are you running?
Where is your AEM wideband placed in the exhaust?
Have you checked for exhaust leaks before it (i.e. if it's placed after the flex section, that might be leaking)?
Do you have a 1g CAS? If so, does your car happen to go into limp mode at any point? This is common with a 1g CAS in a 2g car.
These are great points.
If you have no logger, you should have 2 factory o2 sensors plus your wideband? If the wideband is one of your 2 factory ones, I dont think theres a way to simulate it.
ok guys both o2s are in good condition. Fuel pressure is at 43psi. I put the wideband at the bottom of the downpipe right after the bend. I had it running at 13psi. Im not dumb enough to turn it way up. I just wanted to see. An Im new to dsms so what is the CAS and where is it located. It is a six bolt swap so what should i be looking for?????? Its not throwing any codes. It doesnt seem like its knocking. Just goes super rich under wot and runs like extreme dog crap. It didnt start doing this till I put the silencer in... Had the car at the exhaust shop yesterday and we checked for exhaust leaks from the turbo back and found none..
never mind found the CAS idk if its a 1g or 2g though. hmmm... wonder if its working. How do you test one?
CAS wont cause any of your symptoms? and its most likely a 1g sensor if it is a six bolt swap. the car will most likely not start if the sensor has failed due to no relation of cams on engine cycle. it tells the ecu when to fire and if it doesn't get any signal back it wont start.
OK forgot to answer yes the car is on the stock Injectors the real ? is are they the 450cc injectors or the 390cc injectors. I pulled the silencer back out. Boost creep is back and so is fuel cut but when boosting the car seems alot better until well it creeps up to 20psi and hits fuel cut. Blah... Im in between a rock and a hard spot I really need dsm link and dont have the money...
Yeah I finally got a hold of the prev owner an it does have the 450s. And Ive been researching everywhere. Only thing I can think of is to put a t25 back on there or something of that nature. I know for a fact adding back presure will get rid of the boost creep I just dont get why it runs like dog crap when i add the back pressure back to it.
  • For sale 4G63 Frontline Fabrication V2 Billet Valve Cover
    Frontline Fabrication V2 Billet Valve Cover $750 + shipping & paypal fees* swivel AN fittings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
