Failed Welding LSD...
GSR-VR
111
5
Oct 7, 2012
Albuquerque, New Mexico
So I followed a guide here: How to - weld center diff (lots of pics) - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
To weld my center diff for my 4G63 Turbo AWD Hyundai Excel.
I followed everything to a "T" and am now experiencing a big issue. I cannot for the life of me, get the smaller gear off of the shaft. I've snapped a portion of a tooth off of the small gear and ruined it. :( I've tried heating it up with a torch and even bent my persuasion bar.
I've called it quits for the night. Its past 1am I think.
Any help is appreciated.
:confused:
It needs to be coaxed off gently. Force will only make it bind up. I usually use 2 long flat head screwdrivers across from one another. and pry up in a smooth motion.
you mean this gear right? I use 2 flat screwdriveres to pry it up a little bit, and then use a 3 jaw gear puller to get it out.
I got my puller from autozone for 20 bucks or so, good investment :).
Thanks very much guys! I'm going to let Jack handle this as I see other damage inside the transmission... :(
That gear on the right, if you pull it make sure you put it back in the right way -- I put it in upside down once and started a whole thread on here about why my trans was locking up. Keep track!
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
